Hello!
Background on the issue I am trying to solve: Looking to drive every single street in a city as efficiently as possible.
Solution: At the Esri UC 2022, some of the network analyst folks recommended the following workaround.
1. Create points at every intersection
2. Import those points as the "stops"
3. Run the route as "Driving time" and "Find Best". This will result in driving every single street.
Problem:
1. First problem is that you can only load 150 "Stops" so I am somewhat limited in the route I am trying to plan. Certainly I can plan multiple routes and this is a doable workaround.
2. The MAIN problem is I am running into this issue where the route is not completing itself. Do I need to set the start and stop as the same point? How can I achieve this? See the screenshot below of a small example. Everything is right except for the fact that it is missing partial of the road (red arrow). I am assuming there is a workaround or perhaps I have some parameter set wrong.
The goal is to load 100-150 stops and drive every single street and the whole street. I greatly appreciate any thoughts or ideas!
See my response to your new thread. Basically, use the Waste Collection Solver.
Jay Sandhu
