Directions in another language (VRP)
4111
11
08-26-2020 01:55 AM
NelsonCosta
Why does solve vehicle routing problem make directions in another language, Portuguese for example, and VRP Layer / Ribbon in ArcGIS Pro not? (With the same network dataset)
Thank you
FCC_EnvironmentS_A_
Ok. Thanks.
I followed your advice. I switched to the VRP ribbon in ArcGIS pro 2.6.
NelsonCosta
Thanks again for the arcpy code. It works perfectly.
