Closest Facility - Remove Facilities and Incidents?
1590
11-19-2024 06:43 AM
Harley_Davidson
Does anyone know if it is possible to remove the Facilities and Incidents from the Closest Facility tool in ArcGIS Pro?
In the ArcMap environment you'd right click on the relevant section of the NA tool and you could select the Delete All option.
Thank you!
JaySandhu
You can use the GP tool Delete Rows to delete the selected (or all) rows of a feature class like the Facilities or Incidents.
If you have the feature attribute table open, you can select rows and right-click and choose Delete Row.
Also, if you are re-using a CF layer to load another set of facilities or incidents, you can on the Add Locations tool turn off Append To Existing Locations and that will delete the previously loaded data and add new locations.
Jay Sandhu
JaySandhu
Jay Sandhu
Harley_Davidson
Thank you, Jay.
Can I just check that this is deleting the features from the Closest Facility tool and not deleting the features from the source data being used as both Facilities and Incidents?
JaySandhu
Once data is loaded from a feature class to a facilities or incidents layer it becomes independent of where the data came from. Deleting rows from a facilities or incidents layer does not impact the original feature class.
Jay Sandhu
