Batch Solving Many Routes
21627
23
03-14-2012 06:06 AM
ShaharLevenson
Hello all,
I periodically need to calculate the shortest walking distance for over 1.8 million routes (2 points per route).
With such a large amount of routes I cannot use the desktop ArcGIS - loading that many locations isn't realistic.
What would be the best practice? Creating a python script? Using ArcObjects? Something else?
I have been doing the calculations in smaller pieces (100K, more or less) in version 9.x but now, in version 10, I want to improve the process and do it in one "chunk".
I have access to a strong workstation (20 GB RAM, 24 cores). How can I utilize all the processing potential?
I have no need for hierarchy, restrictions or preserving stop order and all I want is the distance - not the actual routes layer.
Any thoughts?
Shahar.
NaAn
You can throw an exception when no solution is found:
try:
    arcpy.Solve_na(layer1)
except (RuntimeError):
    print "No solution is found for " + str(layer1)
Thanks.
Anna
XiangHe1
Hi,Anna,
Actually, I have the same problem as described in this thread. The difference is that I developed my code in VBA.
I load points into route layer and get the shortest path in a loop. When the route is not possible, the program just stopped and error messages jump out. How can I skip this problematic route and make the program run into the next iteration? Thank you a lot.
try:
Thanks.
Anna
NaAn
Hi Xiang,
You may use this line to continue the loop in VBA:
On Error Resume Next
Thanks.
Anna
PhilHurvitz
I'm hoping someone could modify the code so this could be used as a stand-alone script. Currently it relies on a route layer being in an ArcMap session. I'd appreciate any advice. Thanks in advance.
