Attributes Street Network
1823
01-19-2017 11:44 AM
LuizaFurtado
Hello everyone! I'm starting to create a network analysis and I wanted to start by drawing the shapes, I have doubts about the attributes of the shape Street. What fields are needed?
Take care
Luiza
JoeBorgione
You might want to start here:
What is the ArcGIS Network Analyst extension?—Help | ArcGIS for Desktop
and then take a look at the tutorial:
About the ArcGIS Network Analyst extension tutorial—Help | ArcGIS for Desktop
That should just about do it....
LuizaFurtado
Ok! Thank you!  i will look this tutorial!
ChrisDonohue__GISP
I'm not sure what version you have of ArcMap, but here's the ArcGIS 10.1 instructions.  If it is not 10.1, check the Help for similar topics as there may be changes between 10.1 and other versions.
ArcGIS Help 10.1 Designing a Network Dataset
ArcGIS Help 10.1 Creating the Network Dataset
Chris Donohue, GISP
