ArcMap10.3 Crash
4793
02-12-2015 11:13 AM
MichelleTotman
Every time I try to use merge function under the editor toolbar in Arc10.3 to merge two line segments within a geometric network on a multi-user geodatabase hosted on a SQL server platform, the program crashes. The program is stable when I merge two lines in a geometric network in a file geodatabase located on my computer. Has anyone else encountered this problem? Does anyone know of a patch/work-around for this?
Thanks!
Michelle
MelindaMorang
This sounds like an issue you should report to Tech Support.  They can log a bug for the crash and help you figure out a workaround.  http://support.esri.com/
MichelleTotman
Thanks Melinda. The problem has now been reported to ESRI. I was having trouble believing I was the first to encounter this bug.
