ArcGIS Server Route Finder
2635
05-08-2014 04:53 PM
shaohua
java.net.URISyntaxException: Illegal character in path at index 0: [AGSWS_GEOCODESERVER_ENDPOINT]
at java.net.URI$Parser.fail(URI.java:2809)
at java.net.URI$Parser.checkChars(URI.java:2982)
at java.net.URI$Parser.parseHierarchical(URI.java:3066)
at java.net.URI$Parser.parse(URI.java:3024)
at java.net.URI.<init>(URI.java:578)
at com.esri.adf.web.ags.data.AGSGeocodeResource.setEndPointURL(AGSGeocodeResource.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.sun.faces.mgbean.ManagedBeanBuilder$BakedBeanProperty.set(ManagedBeanBuilder.java:606)
at com.sun.faces.mgbean.ManagedBeanBuilder.buildBean(ManagedBeanBuilder.java:133)
at com.sun.faces.mgbean.BeanBuilder.build(BeanBuilder.java:108)
at com.sun.faces.mgbean.BeanManager.createAndPush(BeanManager.java:368)
at com.sun.faces.mgbean.BeanManager.create(BeanManager.java:230)
at com.sun.faces.el.ManagedBeanELResolver.getValue(ManagedBeanELResolver.java:86)
at javax.el.CompositeELResolver.getValue(CompositeELResolver.java:54)
at com.sun.faces.el.FacesCompositeELResolver.getValue(FacesCompositeELResolver.java:72)
at org.apache.el.parser.AstIdentifier.getValue(AstIdentifier.java:69)
at org.apache.el.ValueExpressionImpl.getValue(ValueExpressionImpl.java:186)
at com.sun.faces.mgbean.BeanBuilder$Expression.evaluate(BeanBuilder.java:579)
at com.sun.faces.mgbean.BeanBuilder.initMap(BeanBuilder.java:328)
at com.sun.faces.mgbean.ManagedBeanBuilder$BakedMapProperty.set(ManagedBeanBuilder.java:447)
at org.apache.jasper.el.JspValueExpression.getValue(JspValueExpression.java:101)
at com.esri.adf.web.faces.component.ContextControl.setValueExpression(ContextControl.java:80)
at com.esri.adf.web.faces.taglib.ContextTag.setProperties(ContextTag.java:92)
at javax.faces.webapp.UIComponentELTag.createComponent(UIComponentELTag.java:230)
at javax.faces.webapp.UIComponentClassicTagBase.createChild(UIComponentClassicTagBase.java:486)
at javax.faces.webapp.UIComponentClassicTagBase.findComponent(UIComponentClassicTagBase.java:670)
at javax.faces.webapp.UIComponentClassicTagBase.doStartTag(UIComponentClassicTagBase.java:1142)
at org.apache.jsp.routefinder_jsp._jspx_meth_a_005fcontext_005f0(routefinder_jsp.java:252)
at org.apache.jsp.routefinder_jsp._jspx_meth_f_005fview_005f0(routefinder_jsp.java:187)
at org.apache.jsp.routefinder_jsp._jspService(routefinder_jsp.java:143)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:388)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:313)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:260)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:646)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:436)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:374)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:302)
at com.sun.faces.context.ExternalContextImpl.dispatch(ExternalContextImpl.java:410)
at com.sun.faces.application.ViewHandlerImpl.executePageToBuildView(ViewHandlerImpl.java:468)
at com.sun.faces.application.ViewHandlerImpl.renderView(ViewHandlerImpl.java:140)
at com.sun.faces.lifecycle.RenderResponsePhase.execute(RenderResponsePhase.java:110)
at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:100)
at com.sun.faces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:139)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:266)
at com.esri.adf.web.util.ADFCompressionFilter.doFilter(ADFCompressionFilter.java:56)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at com.esri.adf.web.util.ADFFilter.doFilter(ADFFilter.java:123)
at com.esri.adf.web.util.ADFSessionTimeoutFilter.doFilter(ADFSessionTimeoutFilter.java:137)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:879)
at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:600)
at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1703)
at java.lang.Thread.run(Thread.java:619)
