Batch export of turn-by-turn directions from routes generated using Calculate Travel Cost in Enterprise Portal or ArcGIS Online
778
08-26-2025 06:57 AM
Status: Needs Clarification
SWATConsultingInc
It would be helpful to have the option to export turn-by-turn directions from the "launch directions" option when a route is created in either Enterprise Portal or ArcGIS Online. At this point when you launch directions, the only option a user has is to select copy/paste or print to PDF. Both of which require manual formatting afterwards. Having the turn-by-turn directions exported in a simple CSV/text file so we could incorporate them in our own mapping environment (i.e., map callouts in Pro) would save us a lot of time. We also have thousands of these written directions to compile, thousands of origin to destination pairs, I can generate routes between these pairs easily, but cannot output the turn-by-turn directions in a batch way. This functionality would be incredibly valuable to add, it would save us many hours!
1 Comment
MaxZeng
I see another similar requirement here, https://community.esri.com/t5/arcgis-network-analyst-ideas/allow-turn-by-turn-directions-export-from... and my coworker Melinda has provided some response to the other one.
Are these two the same requirement? If not, could you elaborate your map viewer workflow, how you load the data, what tool you run, what result you currently get, and what result you want to get instead.
Thanks!
