Register agent without GUI access
555
10-04-2023 02:41 AM
YuriiP
Hi! We currently running a few ubuntu based arcgis instances in AWS cloud. These instances do not have GUI and that means that cannot access agent register page from same instance. We also tried to access it using instance private ip but no success. So, is there are any other way to register it, probably using agent API or something like that? Thank you in advance!
ReeseFacendini
Esri Alum
Does the security group allow 30443? Does the machine have UFW enabled? Accessing ArcGIS Monitor can be accessed over the machine private IP, but it appears the port is being blocked as it's non-standard.
AndrewSakowicz
FYI, this feature is under consideration, potential target Q2 2024.
GeoJosh
I will private message you directly to get more information about this issue.
Josh
