ArcGIS Server Log Fields
1146
12-16-2024 01:00 PM
KevinRathgeber1
When viewing an ArcGIS Server in Monitor, the Logs tab only gives a very limited list of columns.  Allowing at least Machine Name and Source as additional columns that can be displayed and filtered on would be really valuable.  Similar to the log screen in ArcGIS Server manager.
2 Comments
DerekLaw
Hi @KevinRathgeber1,
You can display the Machine Name on the logs panel under the Administration tab now (in ArcGIS Monitor 2024.0.1), please see screenshot.
Not sure what you mean by Source - can you please elaborate?
Hope this helps,
KevinRathgeber1
Oops, my bad. Must be a version limitation - still on 2023.3.1.  There is no Columns option.
For Source, I mean the source column from ArcGIS Server Manager's log (mainly which service is the culprit)
