Layer Rendering Issue: Colors Disappear, Only Contours Visible After Reopening Level
1444
08-18-2025 06:04 AM
FarukKeles
Hi, I’m using ArcGIS in Unreal Engine, and after saving my level and reopening it, the layer that’s supposed to display colors has turned black, and only the contour lines are visible. Is there a known fix or setting I might be missing?
and1
by Esri Contributor
Hi FarukKeles,
Thanks for bringing this to our attention. To help us better understand the issue, what type of layer(s) (e.g. imagery, vector tile, etc.) were you loading? What versions of SDK and Unreal Engine are you using? Thanks!
