Dissapearing buildings from some angles using own layer converted from CityGML
1603
03-21-2023 07:20 AM
RobinKrempel
Spoiler
Hallo everyone,
I have downloaded some CityGml data from this website https://geodaten.bayern.de/opengeodata/OpenDataDetail.html?pn=lod2 . I converted the data using this toolbox https://www.arcgis.com/home/item.html?id=7f765465648049d5a93ef2dc05b1f52b in ArcGis Pro. I loaded the data local through a layer. Now in some camera angles buildings are disappearing. No matter if the buildings are far away or near. In theory a 3D Model should be on every house.
MichaelBranscomb
Esri Frequent Contributor
Do you see the same issue with disappearing buildings in:
RobinKrempel
Hello,
When I am loading only a few buildings in ArcGIS Pro, I can not recognize disappearing buildings. On a larger scale I recognize some issues, which I am interpreting as performance issues. In general there are some program crashes in ArcGIS Pro working with many 3D models. My computer should not be the problem. I have always received this image when i am opening a project, which includes such a slpk file.ArcGISMeldung.png
RobinKrempel
Using the ArcGIS Interoperability Quick Import Tool I accomplished the transformation from CityGML to ArcGIS Scene Layer and that the data ist working correctly.
