Issue with MaterialReference in ArcGIS Maps SDK 2.3
255
06-07-2026 08:10 AM
ws4945894
Hi there...
I'm currently migrating Unity projects from ArcGIS Maps SDK for Unity 2.2 to version 2.3 and I ran into an issue.
There are some projects that rely on MaterialReference like in the code snippet below
zurichTreesLayer = new ArcGIS3DObjectSceneLayer(treeLayerSource, treeLayerName, treeLayerOpacity, treeLayerVisibility, arcGISMapsApiKey);
        zurichTreesLayer.MaterialReference = Resources.Load<Material>("Materials/GreenMaterial");
        zurichTreesLayer.IsVisible = treeLayerVisible;
        arcGISMap.Layers.Add(zurichTreesLayer);
This works perfectly fine in 2.2 (the trees are green, using the sourced green material) but this doesn't work any more in 2.3 (trees are white)
Please check out the screenshots to see how this is rendered in Play Mode
Version 2.2
Version 2.3
It looks like something has changed between 2.2 and 2.3
I'm running Windows 11 Pro, Unity 6000.3.16f1 and ArcGIS Maps SDK 2.3
Any ideas are very much appreciated 🙂
Thanks and best regards
Winfried
AShahbaz
I am not aware of something related to material reference changing between 2.2 and 2.3. I tested our viewshed sample, which uses material reference, with 2.3 and didn't see an issue. Maybe something that the material references for assigning the color was changed?
