ArcGIS Unity SDK find elevation above sea at coordinate
2828
6
09-26-2022 02:02 AM
ChristofferLindellBolin
Hi, I have a question in regards to how I would be able to find the altitude above sea level at a certain coordinate with a longitude and latitude?
Matt_Nelson
Esri Alum
If you know you are looking at the point you can do a raycast.
If not you can query a service like this https://open-elevation.com/
We are also going to add an API for this soon
Matt_Nelson
Esri Alum
ArthurC
Hi Matt,
Is there any update on when this API might be available? Been interested in the Unity SDK and it seems like a pretty crucial feature for general use.
Is there any other way to query elevation at a point from ArcGIS elevation databases from Unity?
Thanks
JohannesMerkt
@Matt_Nelson Are there still no updates? We really need this feature!
MichaelBranscomb
Esri Frequent Contributor
@JohannesMerkt Apologies for the delay in replying.
Which feature do you need? A service that can return an elevation value for a given x,y anywhere in the world? If so - good news - we have recently introduced the Elevation service (beta) | Esri Developer REST APIs documentation.
FrancisPolignano
Any update on this? We also would like to be able to query for elevation at a specified point.
MichaelBranscomb
@FrancisPolignano Do you mean you want to do this via raycast to the elevation surface in the map or make a request to a web service?
You can now do both: raycast is already supported, and we have recently introduced the Elevation service (beta) | Esri Developer REST APIs documentation.
