transition between line widths
1828
05-12-2017 04:17 AM
ChristianeEnderle
Hello,
is there a possibility to get a smooth transition between line widths of road data? See screen capture.
Thanks in advance.
Christiane
XanderBakker
Esri Esteemed Contributor
If you have access to Standard or Advanced license, you can use Representations (Understanding representations—Help | ArcGIS Desktop ) to solve this problem:
You will have to indicate that you want to merge the roads in the Symbol Levels:
And you will have to set the Caps to Round (twice):
ChristianeEnderle
Hi Xander,
thank you very much for your fast and detailed response. It looks neater than before. However, I was thinking of something like this:
Apologize, I am cartographer from the last millenium...
Christiane
XanderBakker
Hi Christiane Enderle , that indeed looks better that what I produced with the symbol levels and representations. Not sure if this can be achieved. Would be great if a real cartographer from Esri jumps in...
