length of polygon
4360
08-24-2017 02:41 PM
Maria_CristinaLara
I need to calculate the longest length of about 500 rectangles. I tried using feature to line, split line at vertices, add geometry attributes, but this assumes I only have 4 vertices - not always the case. Any thoughts on how best to do this?
MicahBabinski
Fun! Your workflow looks pretty legit, but yeah I see what you mean about unnecessary vertices. I would add this one step at the beginning of your process:
Simplify Polygon—ArcGIS Pro | ArcGIS Desktop
Use the POINT_REMOVE algorithm. From the docs:
Retains critical points that preserve the essential shape of a polygon outline and removes all other points. This is the default.
Let us know how that goes.
Micah
DanPatterson_Retired
From arcmap tools Minimum bounding geometry using minimum width option
or if you are using shapefiles Bounding Containers... with the minimum area bounding rectangle option
Both will give a width, length and orientation option
