Legends in ArcGIS Online
6783
04-26-2015 06:59 PM
AllyNauer
Is there a way to customize the legends in ArcGIS online? It currently shows many symbols that weren't used in the map. It also doesn't show the appropriate color of the shading either.
Thanks for any and all help.
SepheFox
Can you post a screenshot of the problem?
EricWorthington
I have the same issue.  From ArcMap I build a definition query to display only items tagged with "Active" out of a total of 4 subtypes.
I published the dataset to the server and imported to ArcGIS Online webmap.  It displays on the map only Active projects, however the legend contains all the subtypes, even though I only want to see Active.
I do not want to save out Active projects and publish because I'm pulling data from an SDE where the data is always being updated and I need the most current data displayed.
I just don't want to see the other subtypes in the Legend.
Ideas?
BrianO_keefe
Honored Contributor
Did anyone ever get a satisfactory answer to this question? I have the same issue with a Crime map. I definition queried out the crimes that we display, but the legend shows 'everything.'
