desktop 10.2.2 crash
6985
06-25-2014 10:10 AM
dougscrivener
I am running Desktop Advanced 10.2.2 with Aviation Charting 10.2.2 loaded.
I am experiencing crashes during normal Desktop edit sessions. Crash does not occur if I uninstall Charting 10.2.2
Same experience with 10.2.1. Crashes occurred with Charting 10.2.1 and stopped when Charting 10.2.1 was removed.
Any advice would be fantastic. Cheers Doug
SeanGrant
Doug,
I have sent you an email asking for some more information.
Sean
SébastienHaule
Hello,
I have the same kind of problem : ArcMap (ArcGis 10.2.1) crash during desktop edit session.
This is the messages from log file :
2014-07-24 13:44:12|   0.5|  0.0|INFORM|Data Interoperability (20130911 - Build 13540 - WIN32)
2014-07-24 13:44:12|   0.5|  0.0|INFORM|FME 2013 SP4 Beta (Build 13540)
2014-07-24 13:44:14|   2.0|  1.6|INFORM|FME Session Duration: 2.5 seconds. (CPU: 1.2s user, 0.8s system)
2014-07-24 13:44:14|   2.0|  0.0|INFORM|END - ProcessID: 5692, peak process memory usage: 207632 kB, current process memory usage: 207384 kB
I have this problem on my Personnal Computer and on my Notebook.
If you have any idea to help me, you're welcome !
Best regards
Sébastien Haule
SeanGrant
Does it crash when you are running an ETL (Data Interop) tool? Do you also have Charting installed?
Sean
SébastienHaule
Dear Sean,
No ETL are running when it crash. Charting is installed but the extension is not checked on the extensions management box. Thanks in advance for your help.
Best regards
Sébastien Haule
SébastienHaule
Dear Friends
I just download and install the Mapping and Charting Solutions 10.2.1 Patch 2 dated 05-16-2014 and ArcMap seems to work without crashing during desktop edit session !
Thanks for your help !
Best regards
Sébastien Haule
