contour
3591
8
10-06-2019 06:47 AM
GERTISEDO
I have dem and a want to make contour for  map on scale 1:250.000 can you help anyone  for this
DanPatterson_Retired
There are numerous ways to produce a contour map depending on your license options
Search Result | ArcGIS Desktop
once done, make a layout at the desired scale
GERTISEDO
hi Dan
Please could you help me with video if you want i can send my DEM
lots to choose from thanks to Dr Google
https://www.google.ca/search?q=esri+contour+video&ie=&oe=
GERTISEDO
hi  I have see this video... but they havet something  contour form DEM for scale 1;250.000
The principles are the same, you will have to adapt them.  The scale issue isn't about contouring, but about making a map from the results (aka a layout issue)
GERTISEDO
yes of course but I need the interval of contour [10,20,30?} that  i generation on DEM.....[in the end for scale 1;250.000]
You will only get those elevation values when you specify them and your data is within that range.
Perhaps you should show what you have tried
GERTISEDO
For map in scale 1;250.000 the interval of contour is 250 ?
