aeronautical
2742
6
01-31-2018 02:11 AM
tinigjeo
Hi
Could I do OLS with arcgis 10.4.1  and make another work for example in runway,Obstacle ect
if you have any example its more better
DanPatterson_Retired
OLS.... as in Ordinary Least Squares
If so, and you have the data, and the conditions for its use are met, then yes
http://pro.arcgis.com/en/pro-app/tool-reference/spatial-statistics/how-ols-regression-works.htm
Otherwise, clarify if this isn't the normal useage of the OLS term
tinigjeo
HI
MY question is for obstacle limitation surface and if i can do with arcgis 10.4.1  and  what are the tools because I havent
arcgis aviation or charting for  more i need the one example video this is perfect for  help
Never heard of it and even a 'google' didn't provide any links
ShaneBarrett
We would recommend using the OIS tools found within ArcGIS for Aviation to generate the surface automatically based on the runway geometry as an input. Otherwise, there are no other automated tools available within the ArcGIS platform for their creation. You could build the geometries manually, but we would suggest performing all of the calculations for each surface first before generating. Lastly, if you have existing geometries in another format (such as CAD), you could bring them into ArcGIS to assist with the manual creation process.
tinigjeo
Yes I know this in gis aviation But I have simple arcgis 10.5.1 and what I can do now if it possible do with one toolsOr another ....
Sent from my Samsung Galaxy smartphone.
ShaneBarrett
The workflow to manually create OIS surfaces is possible in ArcGIS for Desktop 10.5.1 using standard Editing tools, but like our previous comments, we would suggest performing all of the calculations before creating the surfaces. There is no automated way in ArcGIS for Desktop to generate the surfaces. All of the vertices will need to be manually calculated and created.
