findAddressCandidates with magicKey drops matchId
855
07-25-2025 10:13 AM
msuk1
Hi team,
I appreciate that Arcgis now returns matchId in responses. An issue I've found is that when I search with the magicKey specified, I no longer get a matchId. The same request without a magicKey returns a matchId. I have noticed this issue consistently at multiple locations, eg if you search for Eiffel Tower.
Please resolve as I don't see a reason as to why the matchId wouldn't be returned in this case.
Thanks.
BradNiemand
We have confirmed the issue you are seeing and will look into a fix for a future update.
Brad
msuk1
Ok thanks. For now my workaround is to not use the magicKey returned from the suggest response in the findAddressCandidates request. This will likely affect accuracy of some results so it's not ideal. Looking forward to the fix.
