Is construction data from Dodge Data & Analytics under consideration for ArcGIS Living Atlas?
3435
01-31-2024 04:49 AM
MatthewTsui5
Hi everybody,
My goal is to view live data in an ArcGIS Enterprise web mapping application.
Based on two observations, I have a hunch this possible. First, the article The Business Value of GIS for Design and Construction demonstrated that Esri and Dodge Data & Analytics (leading provider of construction data) collaborated in a study that determine GIS is need in the construction industry. Second, Dodge's has a website (Dodge Construction Network) where a subscriber can export a list of construction projects to a excel document. The data include geographic information, such as addresses and coordinates.
BernSzukalski
Esri Frequent Contributor
Dodge Data and Analytics contributions do not exist in ArcGIS Living Atlas and I am not aware of any initiatives that would include any content from them. I checked ArcGIS Marketplace to check if they had any data offerings, and I see nothing listed there either.
At this point I would recommend contacting Dodge directly at the website contacts you provided above. As far as I can tell, it's a report on a study and not an announcement of premium or Living Atlas content.
Secondarilly, you can contact your Esri account manager to investigate further.
BernSzukalski
MatthewTsui5
Hi Bern,
Thank you for your response.
Yes, I have started discussion with Dodge Data & Analytics regarding sourcing live geospatial data on commercial construction projects within an Esri application
In addition, I have developed a workflow that involves converting XML to a map image layer to accomplish daily updates from Dodge, but there are drawbacks that can be simplified by a map image layer on ArcGIS Living Atlas. I imagine it would
I understand this is currently a niche issue, but I am starting to see the commercial construction increasingly find value incorporating live commercial construction data in an web mapping application. For example,  t Burgex Mining Consultants integrate Dodge Data & Analytics' data in a Esri web mapping application: https://mineralocity.com/2023/08/26/4-u-s-counties-poised-for-explosive-growth-in-aggregate-demand/
