Adding ESRI tapestry data to map
1339
12-26-2024 02:34 PM
Labels (2)
KevinBurel
Hi, novice user, and this is a dumb question.
I am trying to add ESRI Tapestry Segmentation to a map in ArcGIS Online, and get zero results.
When I search for "tapestry" in Living Atlas, zero results.  When I search "tapestry" in ArcGIS Online, I get some results but none of them work in the view of the United States that loads on default with my map.
I would like to add latest available ESRI tapestry data to my map, I can't figure out how to do it, and it seems to have changed from the last time I did this.  How can I get current tapestry data in my map that changes as the zoom level changes, from state to county to town and down to tract and so on?
Searched various ESRI articles but didn't have much luck.  Thanks for your time and help to this novice.
LisaBerry
Thank you for your question. Esri Tapestry data is currently being reimagined within Living Atlas as an updated product, which will likely be available in the format you are familiar with in the coming months. In the meantime, you can still access the Tapestry data using the Enrich tool in ArcGIS Online and Pro, and also within Business Analyst. Here is a resource that may be helpful for you to create a custom tapestry map of your own: https://www.esri.com/arcgis-blog/products/arcgis-living-atlas/data-management/make-a-demographic-map...
