With knowledge graph support in the ArcGIS API for Python, and the guides and sample notebooks below, data scientists, engineers, and developers can easily:
This post will be periodically updated with additional resource links related to Python. Be sure to check out other developer resources for JavaScript and Knowledge Server REST API.
Starting with the Python version (2.1.0.3), the native version in the ArcGIS Pro 3.2 release, you can also use local ArcGIS Notebooks inside Pro and the ArcGIS API for Python version out of the box to create and work with Knowledge Graphs with ArcGIS Knowledge in Enterprise 11.1 or higher. You can also easily share those Pro projects with other analysts.
These python guides will help you get started:
Sample notebooks:
Note to python beginners: you don't need to know any python to run these, simply replace a few ArcGIS login values in the first cells of these notebooks.
Never lose your graphs again with backups! Create a backup of an ArcGIS Knowledge graph you have created to store your data model and data. The backup will be in the format of JSON files that can read to recreate your graph or be shared for others to be able to create the same graph on a different server. Create and load knowledge graph backups
Sample notebooks with a Pro Project:
