We use a zone lookup application to help people, in house and the public, to determine if they are in our service area or not. It's been reliable and worked well for the past year but the past few weeks we have been seeing issues with it returning the wrong results.
Example Address: 1806 Federal Rd, Houston, TX 77015
When first navigating to the application it's a tossup if it will return the correct results or not.
For the address I provided, it is contained within three of the five polygons. However, the application is returning all five layers in the map. The only layers that should be returned are the following:
I'm able to replicate the issue of the time if I do the following:
I've have also been able to get it to return the correct results every time if I do an initial search, clear search location, then search the address again but this adds unnecessary steps to verifying if you are in our service area.
Has anyone else had issues similar to this? If so, could you please share your solutions, this application is used by many people and getting wrong results weakens confidence in the applications we produce.
