My Government Services Configuration Failure
3590
07-20-2015 02:59 PM
BrianO_keefe
Honored Contributor
I've downloaded the MyGovernmentServices files.
I've setup 4 layers in the LGM.
Museums, Libraries, Community Centers, and Fire Stations.
I've placed the MGS (MyGovernmentServices) Application online.
I've edited the Operation Layers in config.js to point to the Layers (whether there is data there or not).
I set the BaseMapLayers to the following:
Set my Extent to "-10689100, 4317350, -10675300, 4323850"
Set the LocatorSettings to use this LocatorURL : http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer
Set the geometry service to our service.
Added both the sandbox and services url to the proxy.
And I get...
Nada.
I've spent a bit tweaking this and that, trying to get SOME reaction, but nothing works...
I'm wondering if anyone that has done the MGS has hit similar walls.
BrianO_keefe
Honored Contributor
Key #1) You will see ZERO points or polygons on your map UNTIL you click or search for a location.
Key #2) This app is HIGHLY (and fairly simply) customizable.
BrianO_keefe
Honored Contributor
