Instant app zone lookup spatial relationship Intersects not working properly
1852
5
07-07-2024 07:13 AM
AronPollner
Hello, I created an instant app using zone lookup, but the option spatial relationship "Intersects" not working properly in the sense that it acts the same as "Contains".
Any help in the subject would be really appreciated.
Thanks in advance
KellyHutchins
Esri Notable Contributor
@AronPollner can you tell me a bit about the data in your app? Or share it if its public? I did some testing and it does look like the queries we make behind the scenes are honoring the change between intersects/contains but there could be something happening that isn't showing up in my test app.
SarahNoakes1
I have exactly this issue too.  I have the tool configured to use the intersects option:
This is the map on opening - note the large orange building in the centre of the map:
If I draw a polygon that cuts through that building, with the spatial relationship set to intersects, it should be returned, but it isn't:
I've logged a call with ESRI UK about it, but if you can help @KellyHutchins it would be appreciated.
Thanks.
SarahNoakes1
Apparently this bug (BUG-000170803) is "In Product Plan" which means it should be fixed within the next couple of releases.
BethRomero
@SarahNoakes1 This issue is planned to be resolved in the next update of ArcGIS Online later this year.
SarahNoakes1
The November update to AGOL was released yesterday and the Zone Lookup intersects issue has been fixed!
