Instant App Accessibility - Keyboard Tab Color
1755
6
04-18-2025 12:30 PM
Tiff
I am working on building an Instant App for a public-facing audience with accessibility in mind. I observed that when keyboard-tabbing through elements on the app, the keyboard tab color is a blue color. The color does not seem to be consistent with the theme colors I have set.
Is there a way to set the keyboard tab to align with the theme?
KellyHutchins
Esri Notable Contributor
You can use the esri-view-outine-color to set the map outline color and you can use the #infoButton CSS here to set a different focus color for the info button
.calcite-mode-light{
 --calcite-color-focus:magenta;
.esri-view{
--esri-view-outline-color:magenta;
#infoButton{
 --calcite-color-focus:yellow;
KellyHutchins
If the app you are using supports custom CSS you can try setting this value to the color of your choice.
Tiff
Thanks @KellyHutchins. I wrote this: --calcite-color-focus:#000000; but it didn't seem to do anything. Any advice?
It also looks like the tab color is blue when it's an app element, but black when it's a text/hyperlinked element.
KellyHutchins
Try this
Which app are you using?  You can set specific styles for the links using something like this:
a{
a:focus{
outline-style:inset;
Tiff
@KellyHutchins this is very cool, thanks! I'm using both Sidebar and Nearby and it worked for both. Thanks also for mentioning accessibility - my Nearby app has an introduction window icon at the top right, and that is the only thing that would contrast the black outline with a green background (due to the theme). Is there a way I can isolate that one specifically to be a different color? Photo below.Tiff_0-1745260176826.pngTiff_0-1745260176826.png
Also, it looks like all of the elements now have a black tab color except for the map (still blue). Thank you again so much!
KellyHutchins
Also make sure to test the color contrast of the focus outline with your apps theming to ensure it continues to meet accessibility standards.
KellyHutchins
.esri-view{
#infoButton{
