Create print service with AGOL only
3510
10-02-2018 03:34 AM
HannekePretorius
Is it possible to create a print service with AGOL, without having access to Server?
We have ArcPro with AGOL access and want to create custom print layouts (for instance field map/ report map/ A3, etc) for use in a WebApp.
What other way is there to import/ use a MXD or PAGX Layout file for printing in WAB?
Tags (3)
TanuHoque
Hanneke Pretorius‌, unfortunately that is not supported. AGOL Print service comes with 8 default templates.
As of now, if you need to use your own layout templates, you must publish a print service with your own layout templates from ArcGIS Pro (2.1 or later) or ArcMap (10.1 or above), and consume your print service from WAB print widget or JS API print task.
Printing in web applications—Documentation (10.5) | ArcGIS Enterprise
TanuHoque
HannekePretorius
Thanks for the reply Tanu.
So a printing service cannot be made without Enterprise? We do have access to ArcGIS Pro (2.2.2) and ArcMap (10.1).
Is there any other workaround within the AGOL domain for creating custom "exports" from AGOL?
TanuHoque
sorry for the delayed response.
yes, that is correct.
Unfortunately I can't think of any.
