Can I set a default selection for Zone Lookup Results?
720
03-17-2025 02:26 PM
CityGIS
I have several different polygon layers in my zone lookup for EMS response.  Is there a way to set the default selection and zoom to a specific layer depending on where the selection is?
If the response is in the city, I'd like it to select the smaller square (numbered) , if it is outside of the city, I'd like it to zoom to the county gird (letter/number).
Sometimes it selects and zooms to the Area of Response (AOR) zones, which is zoomed too far out to be helpful.
Thank you!
https://clovis.maps.arcgis.com/apps/instant/lookup/index.html?appid=794e87c30ded4a20a9192d6034e8f025
BethRomero
@CityGIS besdies setting the scale level, which it looks like you did, there is no option at this time to set a different scale level depending on the result. If it zoomed to the first result, would that improve the workflow?
