Attachment Viewer (Attachment-Focused Layout) — Attachments Not Fully Loading on Initial App Launch After October 2025 Update
644
11-12-2025 01:33 PM
rwygmans
After the October 2025 ArcGIS Online update, which introduced the modernized Attachment Viewer interface and new filmstrip gallery, I noticed that the attachment-focused layout does not load all attachments within the map extent when the app first opens. Only a partial set of attachments appear until I scroll through the gallery or zoom/pan the map—then the remaining attachments load.
The same hosted feature layer (56 points with photo attachments) worked fine before the update, and the map-focused layout still loads all attachments correctly. The issue appears limited to the attachment-focused layout after the October 2025 release.
Environment:
  • ArcGIS Online (AGOL)
  • Hosted feature layer with 56 point features (each with JPG attachments)
  • Attachment Viewer Instant App created after the October 2025 update
  • Tested in Chrome and Edge (same result)
Steps to Reproduce:
  1. Create a new Attachment Viewer Instant App using the attachment-focused layout.
  2. Use a hosted feature layer with photo attachments.
  3. Launch the app.
Observed Behavior:
  • On first load, only some attachments display.
  • Scrolling or zooming triggers additional attachments to appear.
  • No console errors appear.
Expected Behavior:
All attachments should load upon initial app launch without requiring map or gallery interaction.
Notes:
Workaround:
Use the map-focused layout, which continues to display all attachments correctly on initial load.
BhargavCSA
Observed the same issue
