AGOL Local Perspective Template
2943
10-15-2015 06:33 AM
OliverPenman
We are currently configuring web mapping applications and one of the AGOL templates (Local Perspective) we have been using is now failing to open. We had implemented it for ‘Find My Nearest Grit Bin’ and were very happy with the result.
We were previously able to select a web map containing a web map services showing location og grit bins and the appliaction would then display the bins within a specific radius of an address. This no longer seems to be available and the template does not seem to work if 'Show US demographics' is not ticked.
Basically what I am asking, has this template changed recently??
I also notice the configuration wizard now has a part which says
“Sharing this app publicly? This app references a map containing content that requires a subscription to access. Choose the content that you want to allow access to through your subscription. Content marked with Premium Content consume credits from your subscription.”
This wasn’t there before as far as we can remember, do you know if this means we can no longer use this template without subscribing to a service.
Oliver
