Fix popup displayed in Sidebar to match map pop-up config
1183
02-12-2025 06:09 AM
Status: Closed
JAVT
This is specifically for instances when you configure the map to remove all the fields from the popup and just have a title. The sidebar app will show all the fields.
Tags (1)
3 Comments
KellyHutchins
@JAVT  how are you removing all content from the popup. If I go into the map viewer and remove the content from the popup then save the map, close it and reopen it the popup defaults to the list of fields.
But if I add a text element, edit the text and just add a space then save it seems to respect that and will display the empty popup content in the Sidebar app.
Here's an example:
https://jsapi.maps.arcgis.com/apps/instant/sidebar/index.html?appid=c0f0d62c850341ee8c738bb9a94ce73d
JAVT
Adding a blank text element is a good work around . Thanks!
IanWittenmyer
Status changed to: Closed
Please use the workaround provided.
