On mobile devices the map window in Nearby is really tiny when the results are being displayed, zooming to the chosen result doesn't generally show the location on the small map so you have to scroll to find it. This could be avoided by allowing the user to minimise the results panel temporarily to see a larger map or close it entirely. Currently you can only maximise the results panel or return it to its normal size.
