Problems with Insights for ArcGIS
5872
8
06-17-2017 04:59 PM
SalemAlghamdi
I have two problems with Insights for ArcGIS which are:
  • Error 1 (Workbook Card): “Something went wrong”.
  • Error 2 (New Connection Database): “Something went wrong with this database connection. Check to see if the connection properties need to be updated”
 How can I fix this issue?
However, I already installed SQL server and I uploaded Java Database Connectivity (JDBC) files on the portal's hosting server.
EDN_SWORDSIG1
Same issue here
by Anonymous User
Not applicable
Me too. Insights will not display any spatial data. I see the attributes and can even chart them, I just cannot see the.
I get the "Something went wrong" message, which is not helping.
AravindatStoryMaps
Hi Salem,
Thank you for this post. Do you mind if you can expand a little on the ArcGIS Enterprise environment that you're using:
1. ArcGIS Enterprise 10.5 or 10.5.1?
2. Based on the answer to this above question, you'd need to have the appropriate Insights for ArcGIS version: ArcGIS Enterprise 10.5 supports upto Insights for ArcGIS 1.2.1; ArcGIS Enterprise 10.5.1 supports Insights for ArcGIS 2.0 onwards (Documentation reference: Compatibility with Portal for ArcGIS—Insights web help Use tab | ArcGIS Enterprise).
Error 1 could occur during specific workflows. Could you expand on what was the workflow done to cause the "Something went wrong" error?
Let's focus on Error 2:
1. The JBDC Driver needed to connect to SQL Server is sqljdbc42.jar. (SQL Server versions supported - 2012, 2014, 2016).
2. Once you've followed the steps to register relational data store types, it's important to remember to restart the ArcGIS Server windows service on the Server machine.
3.  Additionally, Insights doesn't support database connections to your Enterprise geodatabase. (Supported databases—Insights web help Use tab | ArcGIS Enterprise ).
4. Also verify that the ports to SQL Server can communicate with ArcGIS Server & Portal for ArcGIS machine.
I look forward to your response.
Aravind
by Anonymous User
Not applicable
I am working with Insights for ArcGIS 5.1. Is it possible my ArcGIS Enterprise is 10.5? How do I check this?
Thank you.
Randy McGregor
AaronKreag4
Same issue here with the Insights on Portal and database connection.  10.5.1 enterprise and 2.x Insights.  Went through all of the documents for hours, checked everything and looks good.  Using the 6.0 jdbc on MS site.  Still wont connect to a database.  We have a single server deployment but its pretty locked down.  The database info for the connection should be how we would connect to the database like in ArcCatalog while on network or does the database have to have external exposure and external credentials?  Cant find actual login examples for different deployments. Can you give more info on the login page?  The port field isn't required but in the online document it says it will not work without the port number.  Thanks!
by Anonymous User
Not applicable
Our admin guy told me that the problem was with the version of Oracle that is supporting the gis data. He suggested I used a hosted feature service, and that did the trick. I can see the features.
AaronKreag4
I have no issue with GIS data and Insights. The only thing I am having an issue with is the Connect to a data source – DATABASE – Create a New Connection
Get an error, cant find the regular (non spatial) database.
MuhammadWaqar_ul_islam
I have installed Arcgis Enterprise 10.6 server portal data store and insight 2.2.1 version on single server machine.
Unable to load feature layer something went wrong appers. Tried every thing but unsuccessful to run.
Feature layer  is working fine in portal but not added in insight
Please help in this regards
