Filter not working
2249
06-17-2021 09:42 AM
WillStewart
I'm attempting to create some products using ArcGIS Insights but when I attempt to filter, it doesn't select the data.
Example, I have a field with "Major Issue", if that field is <NO DATA> but I select to include it in it still doesn't pull into my table.
Tags (1)
Scott_atEsri
I do believe this is a bug in Online.
Scott_atEsri
Hi. What version - the latest 2021.1? What deployment option - Online/Enterprise/Desktop?
Are you sure that your table is using the exact same dataset that your predefined filter is using?
I just tested with a dataset in Insights desktop 2021.1 and it seemed ok to me. If you could share a .xls of your data i could try to reproduce. Tech support can help too if needed.
WillStewart
I'm using ArcGIS Online
Scott_atEsri
