Drop down menu to select range of values
1104
05-06-2022 12:50 PM
Ed_
by MVP Regular Contributor
Hello,
How can I create a drop down selection menu such that it has the ability to select range of values. For example,
variable = 1, 2, 3, 4, 5, 6, 7
And the ranges in the drop down menu would  look like this:
1 = Minimal
2-3 = Low
4-5 = Moderate
6-7 = High
How can I write an expression syntax for this in predefined filter> advance?
Question | Analyze | Visualize
Ed_
I found a solution as follows:
  1. Select a predefined filter
  2. Select advanced
  3. Type [FIELD] = 1 > click apply > rename to Minimal
  4. Type [FIELD] = 2 OR 3 > click apply > rename to Low
  5. Type [FIELD] = 4 OR 5 > click apply > rename to Moderate
  6. Type [FIELD] = 6 OR 7 > click apply > rename to High
  7.
Ed_
  2. Select advanced
  7.
