Modify Plot Scale
740
11-16-2022 11:18 AM
Status: Open
Ed_
by MVP Regular Contributor
  • Is there currently a way to edit the y-axis plot scale in Insights online/desktop?
Purpose: Instead of showing the values as 100K or etc. I would like to have the axis value format similar to the one shown in the labels.
  • It would also be good to have the option to set the scale because sometimes the values don't start from zero. For instance, I know packages like `ggplot` or `plotly` in `R` auto scale the y-axis depending on the values but, they can also be edited according to the use case. So, I guess it could help by wrapping those functions into Insights backend. Similarly, in case of a time series sometimes you don't want to show all the years on the x-axis or vice versa so, the ability to modify the x -axis could also be beneficial.
  • Another good feature to have would be to change the angle of the scale values, for example, to change their orientation by a 45 degree angle. This really helps sometimes depending on the kind of the data being displayed on the axis.
Tags (3)
