Dynamic Categories for Floor Aware Maps
1588
05-17-2024 08:16 AM
KevinDohner
Hello,
I am wondering if there is a way to have the Indoors Categories be filtered dynamically? Essentially the idea is, if I have a floor aware map of a building, and setup a category for that building that relates to the restrooms, I can just make the where clause be "USE_TYPE = 'Restroom'" and then that category will only show the rooms that are classified as restrooms based on what the floor is currently selected in the floor filter.
At the moment, if I were to use that clause, then when someone clicks on that category, they will see a whole list of restrooms for the entire building regardless of what floor they are looking at. The only thing I can think of to workaround that is to create sub-categories for each floor which is a bit of a hassle if you have multiple categories that need to be filtered per-floor.
Am I missing some sort of behavior or solution to achieve this?
KadeSmith
I'm unaware of any settings that allow you to make categories floor aware. From what I've gathered using categories, they are configured to help the user find anything in that category that is relatively nearby. It's really more of a "find nearest" rather than a directory listing. This becomes more obvious when using the mobile app rather than just the Indoors Viewer.  If I need to go to another floor to use the restroom because it's the closest one to me, I'll probably want to know where that restroom is.
KadeSmith
KevinDohner
I think that makes sense. I think that restrooms might have been a bad example. I see how showing stuff in a building regardless of what floor you are looking at is beneficial.
 I guess my real gripe is you have a good floor filter that interacts well with just about everything except categories which in some cases could benefit from the floor filter.
BR2023
I have the same ask.  From what I have gathered, the categories in the Explore area are not connected at all to the Floor Filter widget.  For example, the explore lists do not change if you change buildings or floors.  We just released a pilot version of a multi-campus (11 different sites around town, 57 buildings) viewer and almost all reviewers were confused that the list in the explore did not get filtered when you use the floor filter widget.  I'm not sure if that is something I want it to do or not.  As soon as you have it filter that way, someone is not going to be able to find a resource on another floor or in another building by looking at the list.  I would love it if there was a way to nest more levels of category groups to help filter the explore by itself.
