Append tool crashing arcGIS pro
1001
03-15-2025 09:11 AM
YaraBathish
I have ArcGIS Pro version 3.4.2.
The "Append" tool crashes the application every time I run it.
Does anyone have any insights?
AnninaHirschiWyss
I ran into a similar issue when joining layers and filed a bug https://support.esri.com/en-us/bug/joining-a-csv-file-in-a-flooraware-map-with-a-floorawar-bug-00017...
I suggest you do the same for the append tool.
You can try to deactivate floor awareness and remove the level_id from your the layer you want to append to (if that's an option for you).
Best,
A.
HBWiese
I have been having the same issues. Sometimes, removing and re-adding the
features that are part of the append will solve the problem.
Pro is also crashing every time I do a join. Still looking for a solution
for this.
