Train Deep Learning Model tool fails with "empty folder" error in ArcGIS Pro
1143
09-22-2025 12:57 AM
mahmoudabdellah
Problem Description:
I am training a deep learning model in ArcGIS Pro.
The input training folder (from Export Training Data For Deep Learning) works fine and is recognized by the tool.
The issue is with the output folder parameter:
The tool requires the output folder to be empty.
I create a new empty folder (verified there are no files inside).
When I run the tool and set that folder as output, I still get an error saying the parameter is not valid.
DanPatterson
MVP Esteemed Contributor
moved to the arcgis-image-analyst-questions space
What is the folder name?
Spaces or punctuation in the name?
Is it a local folder? and not a usb or cloud-based one?
... sort of retired...
PavanYadav
for a test.. I'll use C:\temp as the base directory. Since the 'mymodel_1' folder doesn't exist yet, I'll have the tool create C:\temp\mymodel_1
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
