"Detect Object Using deep learning" appears not to honor the specified extent
1982
02-05-2024 08:16 AM
VincenzoDeriu
I'm trying to run the "Detect Object Using Deep Learning" tool on ArcGIS Pro, giving the World Imagery basemap as input. To limit the area of the detection, I also set the "current display" extent as environment variable, but I think the tool is not honoring it, since it is stuck at '0%' for many hours.
Did someone else experienced the same issue and has some suggestion?
JeffreySwain
Hi Vincenzo,
I would consider a different input layer for your processing as the World Imagery basemap is probably not the best choice in this situation. Depending on where you are looking to analyze, I would strongly consider downloading the images and using them as the input.
Here is a blog that shows some of the sources you can use to download your own imagery.
 Imagery sources to power your analysis
BobBooth1
PavanYadav
@VincenzoDeriu try setting a cell size as well. you can look up what cell size (e.g. 0.3) your model is expecting.
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
