Image Analyst dlpk Error 003569?
2946
06-21-2023 09:54 PM
Labels (2)
JohannesBierer
in ArcGIS Pro 3.0.2 Image Analyst - detect-objects-using-deep-learning tool I get the error 003569 by using the esri trained model "Land Cover Classification (Aerial Imagery)" on a 3 band aerial image with a resolution of 20 cm.
https://www.arcgis.com/home/item.html?id=c1bca075efb145d9a26394b866cd05eb
Deep learning libraries are installed in the right directory as far as I can see?
ExecuteError: Fehler bei Ausführung. Parameter sind ungültig.
ERROR 003569: Ungültiger Deep-Learning-Modelltyp. Modelltyp NULL, ObjectDetection, InstanceDetection, or PanopticSegmenter erwartet.
Fehler beim Ausführen von (DetectObjectsUsingDeepLearning).
I get this error message by drag and drop the dlpk in the toolbox tool?
Any ideas what this error message means?
PavanYadav
@JohannesBierer Hi. Looks like you are using the Detect Objects Using Deep Learning tool to use the Model. But, for this model you should use the Classify Pixels Using Deep Learning tool. We have more detailed documentation for all pre-trained models here: https://doc.arcgis.com/en/pretrained-models/latest/imagery/using-high-resolution-land-cover-classifi.... You can check which tool the model is supposed to work with. You can also refer to the 'guide' link on the model download page.
Hope this helps.
Cheers!
Pavan
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
PavanYadav
Hope this helps.
Cheers!
Pavan
Pavan Yadav
AI for Imagery
JohannesBierer
Thank you ...
