Image Analyst - Detect Objects Model Definition Problem
1862
04-19-2022 05:59 AM
ShaimaaSarwar
Hello,
I've recently started learning and working with ArcGIS Pro, and I need to use the Image analyst Object detection tool for creating a layer of building footprints using satellite imagery.
I have downloaded the package as recommended, but I have no idea where the files are located so I can provide correct input for the field of "Model Definition", as shown in this screenshot.
Thanks in advance,
Hulseyj
For the Building Footprint Extraction, ESRI has a pre-trained model. You can download here: Building Footprint Extraction - USA - Overview (arcgis.com). That file will be the model definition to use.
Best of luck,
James
Hulseyj
Best of luck,
James
ShaimaaSarwar
Thank you very much, this is exactly what I needed.
