Extract Video Frames to Images tool mixes output coordinate systems in Corner Coordinates
2867
6
07-18-2022 02:31 PM
by Anonymous User
Not applicable
Extract Video Frames to Images tool mixes output coordinate systems in Corner Coordinates.
After running the tool, I inspected some of the output files with gdalinfo.
The Corner Coordinates data appears to be a mix of lat/lon and projected coordinates. Is this the intended behavior?
NickWallingford
Ooof. Yup, that's a bug.
We have a fix for 3.1. We've missed the window for 3.0.1, but I'll try to get the fix in 3.0.2.
Unfortunately there's no workaround.
CodyBenkelman
I've asked our engineer responsible for this tool to comment - so we may update this response - but I looked at an extracted video frame (tif format) using GDALINFO and it appears correct (below) to me - I highlighted the corner coordinates in bold - note these are raw image pixel coordinates, not a projected coordinate system.
c:\image_mgmt_workflows\OptimizeRasters\GDAL\bin>gdalinfo C:\Users\cody6520\Documents\ArcGIS\Projects\ProProject_FMV+OIC_UC2022droneSeminar\ExtractFrames\YUN_0127_multiplexed_GimbalEdited_0000004.tif
Driver: GTiff/GeoTIFF
Files: C:\Users\cody6520\Documents\ArcGIS\Projects\ProProject_FMV+OIC_UC2022droneSeminar\ExtractFrames\YUN_0127_multiplexed_GimbalEdited_0000004.tif
Size is 1920, 1080
Coordinate System is:
COMPD_CS["unknown",
    GEOGCS["GCS_WGS_1984",
        DATUM["WGS_1984",
            SPHEROID["WGS_84",6378137.0,298.257223563]],
        PRIMEM["Greenwich",0.0],
        UNIT["Degree",0.0174532925199433],
        AUTHORITY["EPSG","4326"]],
    VERTCS["WGS_1984",
        DATUM["D_WGS_1984",
            SPHEROID["WGS_1984",6378137.0,298.257223563]],
        PARAMETER["Vertical_Shift",0.0],
        PARAMETER["Direction",1.0],
        UNIT["Meter",1.0],
        AUTHORITY["Esri","115700"]]]
Origin = (0.000000000000000,0.000000000000000)
Pixel Size = (1.000000000000000,-1.000000000000000)
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (   0.0000000,   0.0000000)
Lower Left  (       0.000,   -1080.000)
Upper Right (    1920.000,       0.000)
Lower Right (    1920.000,   -1080.000)
Center      (     960.000,    -540.000)
Band 1 Block=1920x1 Type=Byte, ColorInterp=Red
  Overviews: 960x540, 480x270, 240x135
  Metadata:
    COLORINTERP=Undefined
Band 2 Block=1920x1 Type=Byte, ColorInterp=Green
  Metadata:
Band 3 Block=1920x1 Type=Byte, ColorInterp=Blue
  Metadata:
Are you asking because you're having some problem with the images?  A few important points:
1) if your video is aimed above the horizon, exporting a frame may result in a cropped image
2) these video frames are not orthorectified - ArcGIS is not attempting to apply a lens model, nor fit the image to terrain - so it's not intended to support measurements, but simply provide a convenient visualization.
Let us know if that answers what you need
Cody B
by Anonymous User
Not applicable
Thank you for the detailed response on this. When I multiplex the videos and play them in Pro, the footprint geometry looks pretty good. But the corner coordinates from the tool export are interesting to say the least (the videos weren't take in the middle of the ocean).
Here's a sample:
Size is 1920, 1080
GEOGCRS["WGS 84",
    DATUM["World Geodetic System 1984",
        ELLIPSOID["WGS 84",6378137,298.257223563,
            LENGTHUNIT["metre",1]]],
    PRIMEM["Greenwich",0,
        ANGLEUNIT["Degree",0.0174532925199433]],
    CS[ellipsoidal,2],
        AXIS["geodetic latitude (Lat)",north,
            ORDER[1],
            ANGLEUNIT["degree",0.0174532925199433]],
        AXIS["geodetic longitude (Lon)",east,
            ORDER[2],
    ID["EPSG",4326]]
Data axis to CRS axis mapping: 2,1
GeoTransform =
  58.59252494274197, 2.162131309546567e-07, -117.1850503877213
  -16.59005182917486, -1.071558551224427e-06, 33.18010424409931
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (  58.5925249, -16.5900518) ( 58d35'33.09"E, 16d35'24.19"S)
Lower Left  ( -126501.262,   35817.923) (Invalid angle,Invalid angle)
Upper Right (  58.5929401, -16.5921092) ( 58d35'34.58"E, 16d35'31.59"S)
Lower Right ( -126501.261,   35817.920) (Invalid angle,Invalid angle)
Center      (  -63221.334,   17900.665) (Invalid angle,Invalid angle)
Band 1 Block=1920x1 Type=Byte, ColorInterp=Undefined
Band 2 Block=1920x1 Type=Byte, ColorInterp=Undefined
Band 3 Block=1920x1 Type=Byte, ColorInterp=Undefined
Not sure what's going on here but the comments are greatly appreciated. This isn't a critical issue. I was just trying to squeeze more data out of the exports since the csv output doesn't include all MISB fields.
NickWallingford
by Anonymous User
Not applicable
Thanks for the follow up on this - it's much appreciated.
NickWallingford
As a further follow up, the bug has been fixed for 3.0.2, currently scheduled to be released late September.
Thanks again for reporting this issue.
by Anonymous User
Not applicable
For posterity, I tested this tool with the ESRI FMV tutorial data and still have mixed and incorrect Corner Coordinate output.
No solid evidence, but I think the issue here might be the DEM. I'm using the ESRI Terrain service for DEM input.
