DLPK Error 002667 but Deep Learning Frameworks are installed
5078
13
11-16-2023 12:54 AM
afyute
I was trying to run the Detect Object using Deep Learning tool using a deep learning package, but the tool cannot read the .dlpk file. I am getting the "Error 002667: Unable to intialize python raster with scalar arguments". Upon research, apparently it means that I need to have the right Deep Learning Python API (CNTK, TensorFlow, and so on) installed.
However, it's already installed on my ArcGIS. I'm using the Pro Version 3.1 and my Deep Learning Libraries are also 3.1, meaning that I'm using the correct version. I've already tried uninstalling/ reinstalling my Pro and the Deep Learning libraries but the problem persists.
Does anyone have any idea how to fix this?
RadenAdityaSuryadarma
I have issue with ERROR 002667. I use Arcgis Pro 3.2.0. is there anyone knows how to solve this error?
You need to install the ArcGIS library: GitHub - Esri/deep-learning-frameworks: Installation support for Deep Learning Frameworks for the Ar...
my problem is I don't have library for the "Torch" Module for deep learning analysis. after you install the library, the problem solved. it depends on what library you need.
BenjaminBrower
Has there been any update on this error? I have been running into this with ArcGIS Pro 3.5.7.
