Save brightness, contrast and stretch settings to an image
1624
02-13-2024 01:04 PM
Status: Open
cdanielvarons
When I have to open and close the same image several times, I always have to modify the brightness, contrast and stretch settings again. It would be helpful if there was an option to save these display settings for images that have already been modified once.
1 Comment
PeterBecker
When you add an image to a Map in ArcGIS Pro, the properties/settings you set are saved as part of the Layer in the ArcGIS Pro project file. If you turn then on/off the settings will be kept. If you want to save the save the settings (including function chains) for a single layer then SaveAs Layer and you can add to other projects. For larger numbers of image I would suggest using Mosaic Datasets which enable the extensive settings to be saved for each raster.
