Mosaic Dataset Properties - Time Property for Unique Values
751
12-18-2024 06:59 AM
Status: Open
JonM32
It would be nice to be able to use the tool 'Set Mosaic Dataset Properties' to setup a mosaic dataset to use Time and to use unique times within the data as the Time Interval.
Currently, you can set this property up by opening the properties dialog from the contents pane for a mosaic dataset. However, you can't set this up by using the geoprocessing tool - which has the huge advantage of setting up default properties users don't have to do themselves for mosaic datasets.
Thank you!
Jon
ArcGIS Pro - Mosaic Dataset properties view from contents pane. Unique times within data is an option for the step intervalArcGIS Pro - Mosaic Dataset properties view from contents pane. Unique times within data is an option for the step intervalArcGIS Pro - Set Mosaic Dataset Propeties tool showing no option to set up time interval based off unique values.ArcGIS Pro - Set Mosaic Dataset Propeties tool showing no option to set up time interval based off unique values.
