Layout Template?
946
06-24-2024 08:17 PM
DavidGray1
Hello Community; Is it possible to export a layout as a template file? I have read where you can customize the layout template gallery and import an existing template from there, but can you export an existing layout to be available as a template?  Thanks;  Dave
ChristopherCounsell
MVP Frequent Contributor
Yes you can export a layout as a template. You can export the layout file itself, save the layout as a project template, or save it as a project package:
https://support.esri.com/en-us/knowledge-base/how-to-create-a-layout-template-from-a-layout-for-diff...
JustinPrather
@DavidGray1 ... Thanks for posting your question. Do you mind expanding on what you are trying to achieve? Thanks! I'd like to better understand what you're hoping to do.
