lat&long
3713
12
04-16-2018 01:32 AM
GERTISEDO
hi
I have table with point on UTM system  and i want to save on lat&long system
what can i do for more attach file...  (help with image for save on lat&long)...
RobertBorchert
Honored Contributor
Reading your question again.
Create a new database.  Make a feature dataset in the projection you want to use for your Lat Long
Example WGS 84  or Web Mercator.
Right click on the feature dataset and import features.  Select your UTM feature class and import it into the new feature dataset.  ArcGIS will automatically re- project your data.
Be advised if you project it into a projection that is not appropriate for your location it will skew your data.
GERTISEDO
can you try with my table and  you can see the file .....
RobertBorchert
Honored Contributor
Sorry I am not going to download and open a zip file from someone in an open forum that I do not know.
Create the points first with your  tables UTM coordinates and the re-project it into the decimal degrees.
